Tom_Barb
Feb 11, 2016Explorer II
After I hook up the jeep to the coach I disconnect the battery Negative post, close the hood, get in the jeep place the key in the ignition then turn it to the start position, (nothing happens) then allow it to return to the RUN position. This is the position where you would normally drive the jeep. then get out of the jeep and close the door. (yes it will be unlocked) If any one can steal my Jeep on the run, I'm not going to mess with them anyway.
Once the battery is disconnected you can't lock the electric door locks. I guess you could lock the doors prior to disconnecting the battery and leave the drivers door open until you are ready to pull away.
38,782 PostsLatest Activity: Aug 31, 2026
