carringb
Oct 11, 2021Explorer
Start checking yellow stickers. Not all Class Cs are payload-limited. My sisters has 4,500 pounds of carrying capacity, but hers is shorter. Even some of the bigger ones aren't too bad if you skip the full-wall slide (removing an entire load-bearing wall isn't the best idea anyways IMO).
The E450 holds up fine at max GCWR. I haven't driven a new 7.3L yet but it should be even better, since it has more quite a bit more power (more than the number suggest, since they also rated under the newer SAE engine-dyno standard). Just watch that payload.
The Kodiak wasn't a great a chassis new, aside from the Duramax powertrain. The chassis electrical was problematic, due to brittle connectors and poorly-protected wire-mains. My shop pulled ours out of service because the electrical issues became a driving hazard, but the intermittent nature made it hard to pinpoint, and new harnesses were hard to come by at the time. Possibly impossible now. Any other Super C (as long as it doesn't have the Navistar 6.0/6.4L MaxForce) would be better.
38,782 PostsLatest Activity: Sep 10, 2026
