Daboo wrote:
Can anyone tell me if the 2010 Dodge Charger can be towed on a tow dolly -front end off ground...I am at a state park and the wi-fi is so bad it won't down load the dingy guide...My grand-daughter was told by U-Haul that it could be towed on a tow dolly and I am saying no...believe it is a rear drive...Need someone to verify either yes or not...it is an Automatic Transmission...thanks
I'm pretty sure it's a rear wheel drive.If that's the case the answer is probably not, due to the drive shaft. You could just disconnect the drive shaft, but that would be a real pain. Maybe tow from the rear wheels front down? Weren't some of them AWD?
My Jeep has a transmission disconnect button (rear wheel drive) that you have to go through steps to discconnect the trans from the rear wheels. Are the any tiny buttons around your gear selector? Do you have the owners manual with you?
