holstein13
Mar 20, 2015Explorer
KO wrote:Nope, there is no reason a Continuously Variable Transmission (CVT) can't be designed for four down towing. Other manufacturers do it such as Ford.
Constant Velocity Transmissions (CVT) are being installed. CVT cannot be towed or lub pump installed to get around it.
I've never heard of a Constant Velocity Transmission. I think you meant Continuously Variable Transmission which changes the leverage ratio using chains or belts instead of gears.
38,768 PostsLatest Activity: Nov 21, 2015
