Blaster_Man
Mar 21, 2015Explorer
holstein13 wrote:KO wrote:Nope, there is no reason a Continuously Variable Transmission (CVT) can't be designed for four down towing. Other manufacturers do it such as Ford.
Constant Velocity Transmissions (CVT) are being installed. CVT cannot be towed or lub pump installed to get around it.
I've never heard of a Constant Velocity Transmission. I think you meant Continuously Variable Transmission which changes the leverage ratio using chains or belts instead of gears.
If you bing it, you'll find both kinds of CVT transmissions.
38,769 PostsLatest Activity: Dec 31, 2014
