eheading wrote:
Don't look for a Prius with standard transmission. They don't make them.
It's also not a automatic in the normal sense. It's not even your normal Constant Velocity Transmission... no belt with varying diameter pulleys. It's just a planetary gear with three power inputs... the small gas engine without a disengaging clutch and two AC electric motors. This
Video is worth your time, especially if you own a Prius.
While I have not put mine on a dolly yet, I see no reason to leave the key on... sorry no key to turn so pushing the start button without putting on the brake.
