Alex and Tee wrote:
Well we solved our issue and likely saved a few dollars as well. We had put a deposit on a Bronco Sport and it was supposed to arrive on 7/7. Apparently not a lucky number as that was the day hurricane Elsa rolled through in Jacksonville. A couple days later the dealer told us our Bronco was damaged at the train yard and could not be sold along with another they were expecting. Deposit was refunded and we were back to square one.
I spent days searching from SC to FL for another Bronco Sport Big Bend with the options and color we wanted. Apparently the are made of unobtainium. So, we called the local Ford dealer and factory ordered one with an ETA of mid-October. Well, I will be officially retired as of October 1 and have little confidence it will arrive in time.
Lo and behold a few days later our copy of RV magazine arrived with a special feature on dinghy towing. They had a list of towable vehicles and one of those was something we had considered two years ago. A few hours of searching and …. BINGO!!
Last night we drove to Orlando and picked up our Summit White 2021 Chevy Colorado LT with Crew Cab, 4 Wheel Drive and Red Line package. After we pop on a soft tonneau cover we will be good to go. Although this vehicle can be dinghy towed I plan to dolly tow it. Less expensive, less hassle and the dolly has a foldable hitch for easy storage. I’m happy, momma’s happy.
FYI, you can’t dolly tow a 4X4 vehicle even with a neutral T-case. Both axles need to be either on the ground or on a trailer. You could dolly tow it if you remove the rear driveshaft!
