FloridaRosebud wrote:
willald wrote:
Alex and Tee wrote:
...I guess I will learn soon enough if my decision was the right one and I can always sell the dolly and go 4 down at any time if it turns out to be the wrong decision.
That is sort of what I did. Did the tow dolly thing for a while when first got the Motorhome back in 2012. Only took one season (about a year) to learn it wasn't for me. Sold the dolly, traded the vehicle in for one that was flat towable, and went to flat towing.
That was about 8 years ago; have flat towed ever since.
At least in your case, if you do decide to go to flat towing, you won't have to trade vehicles. You'll already have the right vehicle for it. :)
If/when you do decide to go to flat towing, take a long, hard look at the Readybrake Elite tow bar. Can be had for around $1500, has built in braking, no need to spend another $1k on a totally separate braking system that you have to keep putting in and taking out. With a Readybrake setup, you can easily set things up completely for flat towing for half of that $6k that guy quoted you. Even with someone else doing the installation work.
So let me ask a question about the Readybrake. One of the reasons for a brake buddy (or whatever brand) is if the Toad becomes detached from the MH the brake buddy will apply the brakes to stop it (in theory). How does that part of the equation work with the Readybrake?
Al
There is a breakaway kit. It's essentially a cable that applies the towed vehicles brakes if it becomes unhooked. Simple, mechanical and very cheap.
