cKarlGo wrote:
Now, just so I'm sure this means what I think it means, the manual says:
3. Depress the brake pedal. Move the shift lever
through all its positions.
4. Shift to D and hold for five
seconds, then to N.
And that means, starting at P to shift all the way down to 1, then back up to D and then to N, correct?
Yes, you are correct. Start in P then R then N then D then 2 then 1.... back up to 2 then to D then to N and stop. Turn the ignition key all the way back until it stops which is the acc. position. You are ready to go.
MM.
