I know this should be in the dingy section but there doesn't seem to be as much activity there as here, so if the moderators would be so kind as to let it stay here in the class C section I would appr...
Are you sure your hitch is 24" off the ground. That seems awfully high. Make sure you are on level ground when checking it's height. Most hitches are 16" to 19" off the ground.
