I know this should be in the dingy section but there doesn't seem to be as much activity there as here, so if the moderators would be so kind as to let it stay here in the class C section I would appr...
The base plate on the toad will normally be above the bumper when in use. The base plate mounting bracket will be below the bumper. At least it has always been that way on all my toads with RoadMaster equipment. So I think you not have that much difference in your hook up.
