I know this should be in the dingy section but there doesn't seem to be as much activity there as here, so if the moderators would be so kind as to let it stay here in the class C section I would appr...
Good thing your hitch is close to level. Winnebago recommends against using drop hitches on the View. The frame extensions on the older View's were very light gauge material and subject to bending. I had to install braces on mine - available from the Sprinter Store in Portland, OR should you need them.
