Butch50
Feb 09, 2015Explorer
If you are worried about the tires going flat why not invest in a tire monitor system. You could get by with a cheaper unit for only 2 tires. I run a 10 tire monitor system on my MH and my toad. This gives me the capabilities of watching all the tires on both. I can check tire pressure anytime I want. You would be able to tell if you lost wheel bearing as this would cause the pressure in the tire to go up because of heat generated. On my system it gives me temps also so very easy to see what is happening. You can sure see which side of the rig is in the sun with the temperatures. The sunny side is always about 10* warmer than the shaded side.
Personally I don't like smaller tires on a trailer but that is just me. They seem to work fine for other people just fine. I usually don't like a tire under 14" size and would rather them be at least 15"
38,782 PostsLatest Activity: Sep 02, 2026
