How much of a strain to tow a2008 Saturn vue behind a 1995 class a 35 ft 460 ford unit only has 28k and is perfect. Is it worth it to tow without putting a strain on it THANKS
What no one had mentioned is that if you go the go, you must have the whoa.
Braking is also considered in a max GCVW rating. Even though you will most likely have aux. brake system such as brake buddy, stopping the rig will be interesting if it fails. Stay within the manufacturer's weight restrictions.
