Gene_in_NE
Apr 24, 2015Explorer III
OldHippie53 wrote:One of the first things you should consider doing is weigh your motothome on a truck scale. Usual cost is about $10 to $20. This will give you a better idea on how much more you can haul with your motorhome before you exceed the Gross Vehicle Weight Rating (GVWR). From the sounds of things, your best bet might be to put a lot of things in the motorhome and then only rent a small trailer for the stuff that just don't seem to fit. The motorhome will handle better carrying the load versus pulling the load.
I really don't want to tow anything but I don't know how safe it would be to cram everything I own into the RV like its a moving van...
38,774 PostsLatest Activity: Apr 26, 2026
