theotherbart
Jul 21, 2013Explorer
Francesca Knowles wrote:
I'd ask the manufacturer what your rig can safely tow- but if the only info you have to go on is the GVWR and the(OE?)hitch limit, you might add those two numbers together and presume that's your GCWR. 3,500+12,500=16,000.
Next,weigh the loaded rig. No cheating! It has to be loaded for the road, and allow for you and any companions, too. Add the weight of Jeep, also loaded.
If with all that you're under 16,000 you're probably fine- but do change that hitch, please.
I would change the hitch if I go that route for sure. And I've tried contacting the manufacturer but so far no response. Thanks for the response!
Anyone else have opinions about whether or not this rig could handle towing more than 3500 pounds (with a suitable receiver)?
38,769 PostsLatest Activity: Apr 24, 2002
