F4Jock's avatar
F4Jock
Towing With A 460 Ford
I'm new at this so maybe I'm needlessly worried but. . .
Our 98 Tropi-Cal 33 footer is 460 powered. It burns no oil and the engine and tranny are in good shape but going up a relatively steep hill it downshifts and screams loudly, or maybe it's just that I'm not used to sitting next to the doghouse. My question: Does anyone have experience towing with a 460? Can I do so as long as I don't exceed the design specs? The thing is already slow as heck climbing a decent grade . . . .
  • One key to keeping a 460's OEM exhaust manifolds happy is to never shut the engine down immediately after a long, hot run. Allow it to run at idle or slow speeds for 5-10 minutes to gradually bring the temperature down before shutting the engine off.
  • I have the same engine as you. Just short of her 19th birthday, I rewarded her with a Banks Power Pack. It helps up the hills and getting off the mark. I still like to hear the fan cut in though. It makes the temp drop real fast. As someone said, coming down the hills can be a knuckle binder.
  • I had a 97 32 ft Bounder with the 460 and towed my Toyota Corolla from Connecticut to Kalispell, Montana then down through Wyoming and Colorado. I had no problems. This is a very durable engine, but doesn't breath very well due to the intake and exhaust passages. As others have said, a Banks system will breath a lot of life into this, if you really feel the need and have an extra $3000 laying around. Otherwise, treat it gently and take your time. You'll get there. BTW, no more than every three years, have the whole brake system flushed and replaced with new fluid. Brake fluid is hydroscopic and absorbs water from the air. If enough water is in the brake fluid, it will boil when using the brakes hard and you will lose them.
