Jopopsy wrote:
A couple thoughts. The Ford V10 is a revving motor. The Ford E450 is rated to 22000 pounds GCVWR - it will handle what you're pulling.
You might want to run it w/ the Tow/Haul mode on and see how it works for you.
This may sound stupid, "But Just what is "Tow/Haul Mode" ?
Do you mean setting the Cruise Control? Any brain dead person knows that if you are pulling a Grade of any kind that while you are driving a Motor Home, RV even a Pick Up Truck up for example on Cajon Pass or Conway Summit in California, even if you are not towing anything that you turn off the cruise control.
