Pangaea_RonExplorerAug 30, 2016Toyo M145 valve stem core issuesI recently purchased (6) Toyo M154 245/75 R22.5 tires for my MH from Les Schwab Tires. I checked the tire pressures when I got home. The pressures were correct (105psi front and 95 psi rears) The...Show More
Pangaea_RonExplorerSep 07, 2016I'm a bit skeptical also, but it seemed to work? I'll be very vigilant.
Related ContentMichelin vs Toyo tiresToyo tiresTPMS valve stems issue12 Volt Power IssuePropane valve issues
