We put new tires on our camper several years ago. We looked at RV tires but they were nearly twice the cost of truck tires. We were told that RV tires were designed for the loads an RV puts on the tires and that we should stay with RV tires. We found nothing that supported that allegation. When you think about a box truck it has about the same area on the sides, about the same height and weight, so what is different? One exception, UV protection. RV tires have a compound in them that helps fight off dry rotting when sitting for long periods of time. So if one purchases truck tires, cover them when parked and drive it every other week long enough to heat up the tires; somehow that helps protect from dry rot.
In any case weather my assertions are correct or not we purchased Toyo truck tires. We had a choice of 14 or 16 ply tires. Being from the old school of thought I went with the tougher 16 ply tire. Additionally the dealer added e-balance fluid to the tire. That keeps them balanced at any speed. On a smooth road (few and far between) it's like riding on a carpet of air. There is no vibration from tires, what a ride.
Like any new tire they will handle differently (maybe sticky or something) when new but after about 500 miles everything is normal.
For what it's worth there is a Toyo tire manufacturing plant in the US at Mt. Vernon Illinois. The
