RCMAN46
Jun 20, 2015Explorer
Born To Travel wrote:
I have the non flow thru TST sensors and the reason is that the flow thru sensors are slightly longer and would extend past the edge of the steel rims on my toad and may cause a problem with hitting a curb or something...
X2 I first tried the flow thru TST but was concerned about the distance they extended past the rim of the wheel of my truck tires.
I go off road and was concerned if I got into deep mud or snow the flow thru sensor would be damaged.
I use the standard sensor and have not had to adjust pressures more than a couple times a year. Removing the sensor is not much more effort than a valve stem cap.
