Dutch_12078
Mar 27, 2017Explorer III
neschultz wrote:Dutch_12078 wrote:
I didn't see any advantage to the flow thru sensors since you still have to remove the valve caps, so I stuck with the standard TST sensors. I took off the spinning security covers so that removing them is no different than removing a regular valve cap. Without the security covers, the sensors are also lighter and smaller, making them less noticeable.
I like this idea. How do you remove the spinning covers (I have the 510 system)and does that affect the warranty? Thanks
As I recall, the only way the 510 covers come off would be to carefully cut them with something like a Dremel tool. And yes, I'd expect it would void the warranty. The 507 sensor covers are removed by just taking out three small screws, just as you would to change the battery. There wouldn't be any warranty issue in that case, since the cover can easily be reinstalled.
