Flanz
Mar 27, 2017Explorer
After reading the replys here and doing a lot of research I've decided to go with the non flow thru sensors. Looks like these will be the smallest, lightest, and easiest to work with when you remove the locking mechanism. I'll still be using my tire gauge to check tires prior to leaving campgrounds.
During my research it appears that the sensors used by a few manufacturers are the same or similar technology. The flow thru sensors have two schrader valves associated with it. This would put five schrader valves on my inner dual tires creating too many failure points.
Thanks to all for your replys and recommendations.
Paul
Paul
