JoeH
Jun 12, 2015Explorer III
Instead of messing with extensions that will eventually leak/fail, you should check into getting proper replacement valve stems This , Borg Tire Supply, is a source I've used. They are expensive and you have to dismount the tires to install, but they are much more reliable than the extensions
