gatorcq
Jan 19, 2016Explorer
Are you leaving the Inverter ON? This error is related to the load on the Inverter side - not the charging side. Meaning you have left the inverter on and the items on that circuit is overloading the components. And since you have stated that the COOLING fan is making noise (going bad). I suspect that is what is causing the problem. Install an external fan somewhere on the unit so the INSIDE can get airflow
38,769 PostsLatest Activity: Apr 04, 2026
