dougrainer
Jan 19, 2016Nomad
gatorcq wrote:
Are you leaving the Inverter ON? This error is related to the load on the Inverter side - not the charging side. Meaning you have left the inverter on and the items on that circuit is overloading the components. And since you have stated that the COOLING fan is making noise (going bad). I suspect that is what is causing the problem. Install an external fan somewhere on the unit so the INSIDE can get airflow
From the manual. It can be EITHER the Invert or the Charger. IF it happens when the INVERT is OFF (he is in storage) then it is either the charger section or more likely the fan is not running like it should and the fan needs replaced. Doug
"The “Otemp/Less Load” System Status message indicates the
inverter/charger transformer and power components have
exceeded a safe operating temperature. Reduce the load on
the inverter. When the unit cools, it automatically resets and
resumes operation. If this condition occurs often, make sure
the inverter is in a cool location, has adequate ventilation, and
the cooling fan is operational."
38,769 PostsLatest Activity: Apr 04, 2026
