YC_1
Jan 19, 2016Nomad
Find the manual to check the error code. It may not want to charge a "frozen battery". It may just think they are frozen. Warm the sensor up with your hands and see if the error goes away. The noisy fan is probably telling you the unit is not getting proper cooling. Good time to get the batteries charged with a portable charger. Remove the negative leads and then remove the inverter/charger. Get it fixed. Leave the negatives of the batteries offline.
38,769 PostsLatest Activity: Mar 31, 2026
