moparmaga2's avatar
moparmaga2
Traded in the Class A DP for a class c!
Sorry to say I traded in my beautiful Class A DP 2009 Safari Cheetah in for a 2015 Class C Jayco Greyhawk.
The reason you ask? The Caterpillar C9 in that thing is a piece of $&@$. It broke down for the last time a few weeks ago when it threw two injectors on the way home from Arkansas.
The total warranty bills on just the engine alone in 4.5 years are right at $40,000. I was terrified to own it out of warranty and I was tired of my wife crying whenever the check engine light came on (almost every trip)
That RV did take us to Alaska and back, although it broke down 4 times.
The problems? 4 turbos, a water pump, 4 injectors, oil level sensor, fuel pump, compressor leaking oil and cat will not fix, exhaust regen problems multiple times, a serpentine belt, and an alternator and radiator (the last two are not cats fault). All in 40000 miles. Many of these miles we're going back and forth to a cat dealership.
A shame, since the House part of the rv never gave any trouble.
This time I went ultra simple with an anvil reliable v10 and ford transmission. I am afraid the Cheetah has scarred us for life. I will continue to watch you class A owners going down the road and remember the (very limited) good times we had in it. Maybe time will heal the wounds and one day I will have another.
  • I would recommend that you check the adjustment of the Hellwig springs on your Greyhawk. They should be adjusted so that there is not more than 1" clearance to between the Hellwig helper springs and the Ford factory springs. Another thing to check is the installation of the rear leveling jack system. There must be at least 7" - 8" of clearance from the ground to the bottom of the landing jack pads. If there is less you need to have the dealer move the jacks up so that they are installed correctly. If you have issues with sway and being blown around by wind and or trucks you can install a Roadmaster steering stabilizer and a Hellwig front sway bar. The Roadmaster steering stabilizer is a life saver! If you install hush mat in the doghouse you will dramatically reduce the engine noise in the cab.
  • Sounds like you got a lemon. My RV is 10 years old this year and all I've ever done to the Caterpillar engine is change the oil. Not one thing ever has gone wrong with it. The only repair to the entire freight liner chassis I've ever even had to do was a broken grease seal in the front suspension.
  • Sorry to hear of your problems, I would have dumped it too. Good luck with your new ride. ENJOY!!!
  • I hope you have many wonderful miles in your new Jayco Greyhawk! They have a great product and customer service. Might not be the big fancy but should serve you well. ;)
  • Wow, what a horror story. I, too, would have dumped that unit as it would have driven me nuts.
    Our 2008 Monaco product has run very smoothly with the Cummins engine. I've had a couple of campaigns on the engine over time but nothing was ever a show stopper. A couple of times we got a code that said we had 'blow-by'. On closer inspection, the first time nothing was found, the second time it was a filter that needed to be replaced. All good so far with almost 70,000 miles. (2008 Monaco Dynasty-on consignment).
    Good luck on the new purchase!
    MM.
  • Congrats on your upgrade. Let us know how you like the Jayco.
    Enjoy your travels.
