RCWannabe
Nov 24, 2013Explorer
Storing the trailer at the park could be an issue or an added cost, depending on the park you stay in. Tongue weight is an issue as mentioned above, you will have at least 10% of the trailer load on the tongue. Expedition is 5800lbs dry weight plus 1000 or more lbs trailer, so probably 700 lbs or so on the tongue, which may be too much for the MH receiver. If you end up over 7500lbs I am pretty sure, by law, you have to use a weight distribution hitch and I don't know that they can be used on MH (In Ontario it is law from what I understand, may be different in the US).
38,769 PostsLatest Activity: Apr 04, 2026
