ThorResidencyNe
Jun 15, 2013Explorer
I have the sensor mounted in the test port which is right above the pan on the side of the transmission. In regards to an extra cooler, I have the radiator cooling, plus the factory cooler. Can I just splice into the exit port on the factory cooler and run it into another tranny cooler with fan? Will the transmission push the fluid through the radiator and 2 cooling units?
Thanks again for the help.
38,768 PostsLatest Activity: Nov 21, 2015
