bob_nestor
Jul 18, 2020Explorer III
rgatijnet1 wrote:
Transfer switches have been known for the individual wire connections coming loose. Make sure that NOTHING electrical is connected and then take the cover off of the transfer switch and tighten all of the connectors. This may solve your problem.
I'd also check the contact switches insidw the transfer switch. Normally a transfer switch is wired such that the default position is to prefer shore power and the contact switches inside are held in that position with springs. But if the contacts have a build-up of patina or they're pitted from arcing they might not make good contact. When this happens the junction can heat up and the switch could open. I'd also check to make sure the springs are still in good shape.
