2008 tiffin allegro bus, I have no power to rv, found tripped circuit breaker inside house, have power to transfer switch now, is this a resettable item or would it be shot. Can I jump battery to ...
So, you are on 50 amp shore power (only way to have 240 VAC). And, you have confirmed polarity: 50 amp shore power outlet: Each outer straight= hot Center straight= neutral Center round= ground
SO: Either outer to either center straight or center round= 120 VAC Outer straight to outer straight= 240 VAC Center round to center straight= 0 VAC
