ThorResidencyNe
Jul 23, 2013Explorer
The sensor is in the test port bung on the side by the pan. I did test the tyranny for slip. The rpms did not jump when I pushed slightly on the throttle. The only noticeable change was if I let off the throttle and then got back on. Then the rpm changed about 200 rpms.
