Arizona_Kid
Aug 13, 2014Explorer
"The upside: FWD cars can actually be pretty tenacious in the snow because the weight of the engine/transaxle is sitting right on top of the drive wheels. FWD is vastly better in the snow than a rear-wheel-drive car. With a good set of all-season or snow tires, you will probably be able to make it to work unless the snow is really deep — in which case it’s the absence of ground clearance more than anything else that will cause you to get stuck. FWD is also more economical — both to buy “up front” and to operate over the life of the vehicle. You’re not paying extra when you buy the car — and you’re not paying every time you gas up to lug around equipment you only use a handful of times every year."
"The downside: FWD cars are weight-biased toward the front, which is a built-in design limitation as far as handling/performance is concerned. Also, the wheels that propel the car must also steer the car, which isn’t optimal for high-speed driving/cornering. This is why most race cars and also high-performance cars are rear-wheel-drive. FWD is fundamentally an economy-oriented drivetrain layout designed to cut down on vehicle weight, simplify assembly and reduce manufacturing costs."
"The bottom line: FWD is a good choice for the average driver who uses his vehicle to get from “a” to “b” and would like to have decent traction on those few days each winter when there’s some snow on the roads."
"- See more at: http://blog.motorists.org/winter-driving-rwd-fwd-awd-4wd/#sthash.3R6CgOCS.dpuf"
