donn0128
May 26, 2017Explorer II
If that is a joint seam and it appears to be. Then go buy a roll of butyl putty tape, carefully remove the,vinyl piece. Under it you will find a lot of screws. Take the screws out, and carefully lift the aluminum off. Clean everything apply a new bead of the putty tape, screw the trim back on, clean up the excess, apply a bead of Dicor, put the vinyl cover back on. Done!
38,777 PostsLatest Activity: May 19, 2026
