rgatijnet1
Jun 13, 2019Explorer III
I assumed that you checked the obvious which is the fuel level in the main fuel tank as well as the OIL level in the generator. This may also be an issue with a crack in the rubber incoming fuel line to the generator, which is allowing air to reach the carb instead of just fuel.
