viajante's avatar
viajante
Triple digit heat! Generator won't run
We have a real issue! Triple digits, ready to leave for our trip in one day and the generator won't run the a/c.
We had unplugged shore power to cool the 2008 Itasca down for some pre-trip honeydo's, Went outside to see if it was cool enough and someone had plugged the #@%$ thing into shore power with the generator running! We've had some issues with things being touched in the past - but nothing this bad. Now, I've turned everything off and left the mh sit for 20 minutes. Returned and generator turned over and all seemed to be working till I added the a/c. It would not run it!
Anyone have any ideas what may have occurred, or better yet what do I need to do to fix this???
  • You need to review and learn your Circuit Breaker box. Hence, CBs. Electrical panel for coach.
  • Turn off very circuit breaker and turn back on. If everything works on the generator except the A/C, then I would suspect the circuit breaker fr the A/C has tripped. Also, double check the operation of the A/C on shore power- be sure the A/C itself is not the problem.
  • CA Traveler wrote:
    Reset and set the CBs. Check the voltage at the ATS to determine if you have gen power on the input and output.
    Not sure what that is?
  • Reset and set the CBs. Check the voltage at the ATS to determine if you have gen power on the input and output.
