3_in_the_RV
Jul 14, 2016Explorer
Sam Spade wrote:3 in the RV wrote:
Is this normal for it to be running all the time or did that indicate I problem I did not recognize?
Yes and no, in that order......probably.
The battery charger needs some air circulation, more so when the ambient temp is high.
YOU NEED A MULTIMETER TO CHECK VOLTAGES.
Without that, nobody can help tell you if you have a problem or not.
OK I checked voltage and I have 10.46 on each of the batteries. When I turn on one little ceiling light and the little porch light it drops to 9.95. However, when put on the battery charger (completely out of RV) they appeared to charge easily and indicated a full charge. As a point of reference I checked the engine/chassis battery and it read 11.88 without the vehicle running. Does this give everyone some ideas of what might be wrong? I really appreciate your help. Thanks!
38,771 PostsLatest Activity: Apr 14, 2026
