daveshan
May 25, 2013Explorer
2oldman wrote:daveshan wrote:If he has a rig big enough to carry that, the a/c is way too small to cool it.
he has 710w of solar, and a battery bank to back it up.
I think he covered that
Off Grid'r wrote:
I thought I would Post a recent upgrade I did to BoonDock'R Since i have read all over the place that you cannot run A/C on Solar power and that there is no Efficient means of Cooling an RV in the Heat of summer. The Unit I chose to use is a Haier Brand Model ESAD4066 with a energy efficiency rating of 12. Its 500 watts and 4.5 amps with 6k BTU of Cooling power. Now this unit will not cool a large rv but will cool a smaller one or a section of a large unit. I have mine setup to cool the Rear bedroom with no other insulation/efficiency upgrades. Other upgrades like energy star Elastomeric rv roof coat will help reduce heat buildup by 30% and is planned for Boondock'r Late this Summer. The A/C Unit also acts as a Dehumidifier when in use and works great for late winter humidity buildup. I did install this unit in the Rear emergency exit but is constructed to be able to be pulled out easily enough in an emergency still allowing access. A couple dabs of Geocel adhesive/sealant in the right spots helps stop vibration or movement of A/C while still being able to "Rip away" in an emergency.
38,767 PostsLatest Activity: Sep 19, 2016
