jillhop's avatar
jillhop
Turn signal blink frequency
This isn't really an RV question (at least I don't think it is ...) but more of an automotive one. When I set out in my 1998 Coachmen (Ford E350/V10) this morning, I noticed that the left turn signal was blinking at a very fast rate. Sure enough, I checked the turn signals, and found that the left rear turn light was out. I replaced the bulb (it's working fine) but the blink frequency hasn't returned to "normal." The right signal still works as always.
Remembering back to the days when I drove this vintage of vehicle, I remember the faster blink frequency when a bulb was burned out, but it always returned to normal when the bulb was replaced.
Is there a fuse or something that I should check? Something else?
  • Check for other burned out bulbs. Maybe remove the fuse or disconnect the battery to "reset" the circuit.
