supercub
Oct 01, 2020Explorer
Turning off the generator with the AC going?
Kinda messed up today. I had the generator running and the invertor switched on, ( usually turn the invertor off when running the generator) both AC units were running. The AC's cycled off and a few minutes later I was going to leave, so turned off the generator, forgot the AC's were on, but not running. The inverter was still on...........will this hurt anything........will the AC's try to run off the invertor? I have 4 house batteries. Do you think I hurt anything? I wasn't around, so don't know if the AC's tried to run or not off the batteries.
I've always turned the AC's off prior to turning off the gen or making sure the AC switch is off before starting the gen.
Does it hurt to turn the generator off with the AC's running?
Does it hurt to turn on the generator with the AC switch "ON" so they'll try to start as soon as the gen comes online?
