DrewE
Oct 01, 2020Explorer III
So far as the generator is concerned, the AC thermostat "on" but not actually cooling is no different than the AC thermostat "off." In both cases, the air conditioner is not running and hence not consuming power.
As was said, best practice is to turn off loads before shutting down the generator. However, it's generally unlikely that failing to do so accidentally will cause trouble. It's in the category of things to avoid, but not in the category of things to keep you up all night worrying about should they happen.
Shutting the thermostats off before starting the generator is strongly recommended; starting under load, especially a heavy load such as two air conditioners starting up simultaneously, is rough on the generator. Let it start up and stabilize (and ideally warm up a bit), then add the significant loads individually so far as it is practical to do so.
