Here is a neat diagram of the ANTENNA WALL PLATE my two trailers have...
I never had much luck trying to use the so called SAT TV outside connections... Neve could get past the outside trailer TV splitter to grab the required SAT ANTENNA DC VOLAGE to operate the dish...
The only way I could ever get my portable SAT TV to work was to run two RG cables into the trailer from the two SAT OUTPUTs on the dish head and connect to a SAT RCVR at each location we wanted to watch SAT TV. Then I would run VIDEO cables from the SAT RCVR to the VIDEO INPUTS to the TV we wanted to watch it on. Then use the TV control to select the video input for SAT TV or CABLE for regular TV coming in from the cable or outside Batwing antenna...
Roy Ken
