wa8yxm
Oct 06, 2014Explorer III
IF you did not buy the RV new.. Many times the prior owner may have re-tasked that park cable lead for Sat TV use as teh LNB cable,, Frankly this is not a good idea, but if that happens and you have the wall plate.. See above posts for how to re-connect it.
IF you have a box of many buttons.. The connectors on the back should be labeled... Just had a poster in another forum who found the wires connected wrong.
For that matter,,, In a different panel (The back side of the tv itself) on my coach it came from the factory wired wrong. As it happens. I'm trained in how to hook it up RIGHT. Side note 2... I would, at a guess, thing that around one in ten RVers likely has enough training to do it right, if not more.
38,782 PostsLatest Activity: Sep 10, 2026
