wolfe10
Jul 20, 2013Explorer
joraz wrote:Individual wires was for antenna up sensor and not antenna itself.
Your old system needs to be complately removed. Then install the equipment for the Jack antenna system. The old winegard power supply is blocking the Jack system.
Now, we're getting somewhere! So there must be a Winegard power supply somewhere in my coach. Just gotta find it! Unfortunately, I don't have a schematic for this particular system. I can call the factory though. Anyhow, I really have to use the existing coach coax unless I completely redesign everything. Now I'm thinking if I can find the power supply, I can bypass it and be in business. Thank.
jor
NO. The Jack antenna can use the OE Wingard 12 VDC booster OR, yes you can remove the Wingard booster and use the Jack 12 DC booster.
We are running our TV on the Wingard booster with Jack antenna-- works just fine.
Hopefully someone more A/V friendly than I will respond, but in the back of my mind, I recall checking for 12 VDC between coaxial center and jacket up on the roof (from either the Wingard or Jack booster).
And, at least on most Foretravels, the Wingard booster is UNDER the back right closet false-floor. There is an inline fuse in/on the Wingard unit.
38,782 PostsLatest Activity: Sep 01, 2026
