a_j_wExplorerOct 13, 2015Tv in slide outHave 2005 I country coach want to install tv in slide out see new models with tv in slide.do they have a kit for this .
3 RepliesReplies sorted by NewestdougrainerNomadOct 13, 2015No, they do not have a kit. Each OEM makes their own bracket and recessed space for the outside TV in a Slide. DougGoldencrazyExplorerOct 13, 2015I assume you want to move your TV location from the front overhead to the side which happens to be a slideout. I had that done on a former coach. They found pathways with other electronics to run the cable.EffyExplorer IIOct 13, 2015Do you mean an outside TV? Doesn't necessarily have to be in a slideout.
Related ContentEasy way to remove slide topper?arctic fox slide adjustmentslide out 120v harness issuesTV UPGRADE QUESTIONSTV
