I need to add an HDTV to our bedroom. We found a 19" that will fit, but I need to mount it. Do I need to use a mount specially built for an RV, or can I just buy one that fits the TV from Best Buy. Do...
We put a swing mount in the front and back. We purchased a swing mount that could hold a heavier TV so there were no issues with the vibration. We purchased one that allows adjustment in both axes. In the front, we built a frame for it attached to the solid supports already there. In the back, we mounted it on a solid frame member on the side. We put a strap across it when traveling. They are both solid mounts.
