No probably, if yours is analog only, which it probably is, you will need a converter, or a newer TV. Just ran into this problem while tryit to help a friend. He had installed new antenna, and could not get any signal, we were next door and getting many channels. Spend a lot of time and work checking everything out with no results. Finally realized that when he had system working, he had been either connected to cable or satellite. Had not tried receiving a OTA signal since all went digital. Replaced older TV with a new digital LED, everything works great! We did not have a converter available at the time, New TV was a better choice in this case. If you can find one at a reasonable price, a converter will work fine also.
