rjackf wrote:
where did you mount it and what kind of anchor or screws did you use
In my case I replaced an old 13-inch CRT TV that was mounted in a cabinet in my 2002 Roadtrek with a new flat screen mounted on the back of the old TV cabinet on an arm freeing up the cabinet for storage. Using an arm for mounting allows viewing from the very back of the RV and if you swing the TV also from the front seats. Mounting screws into the cabinet in a RT is not a problem since all cabinets are make of an excellent grade of 1/2" 5 ply plywood.
