rgatijnet1
Jun 21, 2017Explorer III
Look at the top of your remotes and see if there is a switch that can be moved that says the remote can be used to control different devices. If you have that switch, just set one remote as #1 device and program the other remote as #2 device. Ypu can also try programming the remotes using different codes since more than one code sequence will work with each TV.
